Purfling and binding glue http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=50733 |
Author: | SnowManSnow [ Mon Jun 11, 2018 8:32 pm ] |
Post subject: | Purfling and binding glue |
What glue do you all recommend for marrying purfling and binding strips before bending? Specifically gluing BWB to the binding for the side strip Sent from my iPhone using Tapatalk Pro |
Author: | meddlingfool [ Mon Jun 11, 2018 8:34 pm ] |
Post subject: | Re: Purfling and binding glue |
Titebond 3. But that's it's only use... |
Author: | Freeman [ Mon Jun 11, 2018 9:12 pm ] |
I cheat and by wood binding with the purfling line already glued on the short side and bend them when I bend the sides. If I want purfling on the top or back of the guitar I sandwich the lines in the channel and wick thin CA into the interface. This sort of shows it - the rose wood binding has a maple line on the bottom, I'm adding another between the binding and the body. ![]() ![]() ![]() I bought one of those binding laminator thingies from StewMac that uses acetone to laminate plastic binding - using it was kind of a cluster so now I just stack the strips in the channel. Acetone only works on plastic binding, since I use wood, plastic, fiber and the little teflon to hold a gap for pearl my glue of choice is water thin CA. Others don't like it, I've had great results with it. |
Author: | Mark Mc [ Tue Jun 12, 2018 7:38 am ] |
+1 for Titebond 3, as it holds together despite the heat when bending. But I agree that it is the only place that I use that glue. Everything else is TB1 or hide glue. |
Author: | Michaeldc [ Tue Jun 12, 2018 8:03 am ] |
+1 for TB3. It’s also the only place I use it. A problem I run into is that the premade purflings I buy aren’t layed up using TB3 and sometimes delam in the bender. |
Author: | ernie [ Tue Jun 12, 2018 8:14 am ] |
Fish glue |
